Guys.. Finally got the car scanned yesterday. No problems as such. The only indication was of throttle body service. Now I have already got this done 2 times, once by my local mechanic and then to double check, by Toyota Capital motors.
The mechanic then recommended that i should use only High octane only. What do u guys think??
The other problem my car had was ABS Braking system not working. Found out that the rear ABS sensors were damaged/broken and ABS system was disabled. Had to change the rear hubs as the ABS sensors are embedded in the Hubs. Cost = Rs 6000 each. Getting the electrical system of ABS fixed Rs 4000. (the ABS light in the panel was disabled very cleverly and was connected with the ignition lights. As soon as the car was started and ignition lights when out, so did the ABS light, leading to no malfunction indication light of ABS).
Total Bill about RS 20000. The ABS system is working fine now.
Has anyone else also faced this kind of problem??
