It seems you have never seen a good headlight on a bike.
Deluxe headlight is the CRAPPIEST headlight i have ever seen on a bike. The main reason is not because of the bulb. Its the "spread" it generates because of the plastic visor. Its just as horrible as on a normal CG125, or infact any other bike in Pakistan.
The fact that its headlight is not "always on" (varies with the RPM) makes this issue even worse. At 5th Gear, on High Speeds ... when the RPM comes down from 11 (to 8) ... the light throw is "just enough to keep you alive" ... NOT enough to make everything visible on the road.
If i had a deluxe, i would immediately scrap its front visor, in favor of a Heavy Bike Headlight infront of it, and a bigger battery to power it (like Piaggio or a GS150).
