You should know what you are talking about, or you should rather try and keep quite and learn first.
Just a recent member, novice views on every thread and using caps lock, stressing words as if you are the only automotive guru left on planet!
5,000Km is way too early for tappets adjustment? Lol...
Amongst our local bikes, their tappets should be adjusted every 2,000kms at max.
Wrong valve clearance not only results in lack of power, more fuel consumption but can also bend your valves and damage the engine.
@poster
Plz get ur bike tuned and tappets adjusted every 2000-2500kms or u will ruin it. GS150 does have hydraulic valves which need less frequent adjustments, but 5,000kms is too much.
2000-2500kms is a safe limit.
Sent from my HUAWEI G700-U10 using Tapatalk
