Need suggestions for Pakwheelers in general and Audio system gurus in particular about the sound system I want to install in my vitz 2007. Current setup is OEM cd player with radio having JDM FM Frequency, a pair of very decent speakers in the front door and NO CONSOLE for 2-din setup.
I?m not a very fanatic about bass so will live without a woofer. Also I want to keep whatever little trunk space vitz has to offer for purposes other than a woofer. Aim is to get SQ although not sure if SQ is achievable without a woofer.
My requirements are:
- A Head unit with navigation and back view camera. I will also need a console for the headunit.
- A good quality (branded) Amplifier ? I think 4 channel- plz specify its rating etc
- Comps for front doors
My plan is to relocate the Pre-installed speakers in the front door to the rear door an d install comps in the front door. Is it possible to use speakers and comps in combo thru a 4 channel amp? As per my limited knowledge, I will need at least 4 channel amp. Please confirm.
Total budget is around 30k ? but flexible if there is some real nice set up recommended by you folks.
I might do it in 2 or 3 steps in about 3 months time instead of compromising on quality.
You are free to recommend any decent setup close to my range however, please let me know the compatibility b/w a particular amp and the comps. Also, if possible, let me know the particular shop/person and price to buy a particular item.
