Hello enerlevel,
I have in my car installed just the basic sound system pioneer pre (usb/mp3), 2channel amp (chinese made) and pioneer speakers, problem is that occassionaly i hear this sound phump phump (like phata hua speaker produce) when I switch on engine, if i increase the volume at max it goes away and then it works fine at lower volume as well, this sound appear sometimes in middle of the drive as well but usually goes away bu increasing a volume, this is the new system installed about few weeks back in karachi, when I spoke to the person/technician who had it installed he said there is some problem with the battery you should have your battery check, I'm not sure if it is related to the battery problem or badly been wired/installed by that person. I also have noise reduction/ removal in placed infront of amp. Please advice. Thanks
i Need Audio/ Pree/ touchscreen system for my Diahtsu Mira(660cc) 2009
The system must be original one which gets original fitted.it should be 100% as shown in this car
SALAM TO ALLdears, my vitz equiped with pre nddn w56 navi with back view camera. can i see back view on screen while moving FWD? camera works only while shift onto R (reverse gear).the Attached VTR cable is available easily in market for my pre? or some one explain the the connection diagram.
Hi bro i have a sony speakers and pioneer woofer running on kole audio amp the system was running fine but suddenly it stopped working there was no distortion or any thing it just stopped...Now the light on my amp is on but there is no sound in speakers or woofer i have checked fuse on amp and replaced them but no luck what will be the problem i will be very thankful to you if u reply me as soon as possile......
check the wires. u have to check if the amp is working or not. connect a cd or usb player with the amp and see if it is working or not
Car's player shut off at High Volume and on AC it fluctuate.....Wiring is OK no Amp just pair of 718+JVC KD-815 Head Unit
bro wires are ok and the amp is connected to cars dvd player front two speakers are working but there is no sound from back speakers and woofer...and amps light is on...
Bhaioo can we install small woofer with 7150UB without AMP ? if yes then which one ?
yr mujay amp suggest karo to run pioneer 308 d4 woofer...should i go for 2 channel or 4 channel and in branded or the other one?
Brother, it is highly unlikely that you will find touch-screen with exact fitting. Nothing ... You can check.
Your best bet would be to visit kabari markets, and search .. no short cuts ..
Brother may these are the 2 problems u r facing:-
1)Check your Rc leads!!!Both...(Pre and Amplifier)!
2)Check your Fader balance from Dvd HU.....It may turns to front speakers!!
Brother go for orion 225 HCCA amp...(If u find it)!!!
Or go for Solid audio F-43 or F-45!!!
d4 k liye orion is just ok. it gives around 200 watts on 2 ohms bridged. for d2 its perfect as it goes up to 570 watts on 1 ohm bridged.
Sir what battery do you have?
Kenwood M615D, VTREK PS2000, Sony GTR 2002 are best.
Sir it can run a sub, not a very good idea, but usable.
Teac 10" SUB 150W, JVC GW1000 350W, Pioneer 303R 250W, Alpine 1042D 250W, Kenwood 3010 200W, Sony GTX 120L 300W are your choices.
Use good quality 12AWG streetwires.
+1!And thank u 4 correcting me Sir!!!
200RMS is bit low power!!!!
But @ 1ohm,I think it is a father of all 2 channel amp!!!
oh yeah that it is. and it is sq as well. people have been using components on this amp as well.
Awwww.....thats Great!!!
Sir,Is it come new???:S
What is the estimated price of this amp,If it is second hand????
no. doesnt come new. its old school amp and price varies... should get a good one for around 4500 if u can find it at which price it is amazing as it can run two d4s pretty good
