Asalam-o-Alaikum Bros,
I need to that what is the Maximum CNG capacity in 40L Factory Fitted CNG cylinder? Usually I got filled upto 6KG of gas, but today a CNG station filled upto 6.75KG of gas. How can this possible? What is Max storage capacity of 40L CNG cylinder in terms of KG.
Thanks!
no one?
it all depends on pressure of the pump lift car hood and cross check,the pump might have pumped in at 220bar or more pressure
Once one of my friends got filled his mehran and the quantity of CNG was 7.7 kgs. so it all depends on the pressure.
measure cylinder in litres, not in kgskgs depend on pressure, and standard pressure is 200bar for CNG cylinderslike 55ltr. cylinder at 200 bars can have 7 kg gas, if pressure is increased it will take more gas, which is not good for cylinder, since you are crossing safety limits.
The maximum CNG in cylinder of company fitted cylinder is 6kg at 200 bar pressure while some CNG stations raised their pressure till 220-230 barrs and in that case the cylinder is filled approximate 7 kgs happened to me most of the timeand the reason for this too much high pressure is that all HIACE and Rickshaw drivers teases them so in that way they can fill up more 4-5 KG,s in their vehicles so that HIACE 100 KM to mazeed CNG pe chal jai geand the CNG stations owners are compelled to do so as they are their regular customers and their vans fill 2 times most of the day
do any one know what is the maximum capacity of CNG is filled in 2009 Mehran factory fitted cylinder??
today it just filled 4.5 KG from empty
i thing pressure kam hoga attock f-11 pe
kahan per acha pressure available hota hy in isb?
thankyou
@all: Thank you very much brothers, its cleared now.
Dear can you take a little pain to go outside islamabad? i mean near Motorway chowk/26 no. ? There are a number of CNG stations which give 220 bar pressure most of the times like AHMED CNG, ATTOCK(GAKHAR) CNG ETC or In blue Area Zoom (PSO, MEHER) is also good.
thanks alot sir for the guidance
yes i can go. 0ne of my friend told me G-11 markaz PSO pump has 220 pressure.
in morning 2.30 hrs to fill cng in que but pressure arent good enough to fill 6kg full ATTOCK-F-11
cam anyone tell me please
1) i want to have CNG cylinder replace to have a full size one? due to 50 km + travel daily
what is the cost??
can two be installed??
what are advantages and disadvantages???
the pressure might be good or the car might have a bigger cylinder like i know some1 who's using 50l cylinder in mehran
How can you install two cylinders in a little mehran? you can, however, install a 50 L cylinder instead of 40 L.
some guys use 55L cylnder in mehran alto ff comes with 55l cyl
