Hi friends,
I want to know what should be the suitable tires air pressure for Daihatsu Mira 660cc Vehicle. I am using this car and i kept 28 psi for rear and front tires but i feel it bumpy. Any valuable suggestion will be appreciated.
Thank you.
Toqeer
If the rim size is 4 x 12 and tires are 145/70 R 12 S then the tire pressure in front and rear tires will be 26 psi (1.8 bar) when car is unladen.
This info is usually provided on the door inside pillars on a sticker usually ?
22 - 28 PSI max please do not risk more then that tell your paid driver to maintain it low do not inflate it like suzuki & rickshaw drivers
My car is Mira 2012. I want to know tyre air pressure size 145 80 13
Uniform in all 4
28 psi in summers 32 in winters -
I keep it 26 in all 4 tyres of 145/70 R12 in my Cuore. Keeps the ride a little softer.
I have Mira ES 2012 with tyre size of 155/65 R14 and I keep 28 psi in all 4 tires.
I just want to ask whether it's ideal for these size of tires or not?
try to search is user manual.
Open right front door and see sticker in which pressure is mentioned 2.6kgf equal to 36psi
