My Car was vibrating in Reverse,Neutral and Sometimes in D. Searched on Net and found IACV is the problem.
The function of the IACV a.k.a. Idle Air Control Valve is to adjust the idle based upon the amount of air entering the engine, then the computer reacts to this information by adjusting the cars rpm.
Reasons why you should take it apart and clean it:
-High idle after your car warms up
-Lumpy idle
-Roaming idle
-Hunting idle
-Fluctuating idle
Only 30 Mins DIY
Now you got to locate where the IACV is open your hood and it’s located directly behind the intake manifold. It’s actually connected to it.
There are totol 2 bolts,2 pipes and 1 Harness.
Remove all the above things and try to close the tip of the two pipes otherwise coolant will leak.
Disconnecting IACV was the most annoying part. Pipes were jammed and my hands are still burning
Circled in Red has to be cleaned. I used water with little amount of Petrol.
After Cleaning. I used blower to dry it.
Reinstalled .
No more Vibration
