Technical Specifications:
Power Train:
Engine: Single cylinder four stroke
Piston Displacement (cc): 196.9
Bore&Stroke (mm): 63.5x62.2
Max Output: (KW@RPM): 14.00@7500
Max Torque (N.M@RPM): 16.14@6000
Transmission: 4 speed sequential with auxiliary reverse assy
Drive: Rear wheel
Clutch: Wet type, 7 plates
Fuel: Gasoline/CNG
Wheel & Suspension:
Tyre size: 4.50-12
Suspension front: McPherson Sturt with coil spring
Rear: Leaf spring with shock absorbers
Brakes:
Brake type: 4 wheel Hydraulic drum type
Parking brake: Mechanical type
Steering type: Re-circulating ball type
Turning radius: 3.9 meters
Electrical System:
Battery: 12 Volts
Ignition System: CDI
Self Starter: Electrical motor type
Fuel Consumption: 25KM/Liter
Capacity:
Seating: 4 persons
Fuel tank: 8 liters
Max load: 300 kg
CNG Cylinder: 24 liters
Body/Chasis:
Reinforced ladder type steel chasis, steel body w/high strength pipe frame
Dimensions (mm):
Length: 2900
Width: 1360
Height: 1590
Wheel base: 1880
Ground clearance: 170
