Page 1 of 8 123 ... LastLast
Results 1 to 20 of 146
Like Tree97Likes
Thread: Home Made ECU for EFI Engine
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Default Home Made ECU for EFI Engine
    hey guys
    I made a Home Made Engine Control Unit (ECU )using PIC16F876A for EFI Engine. Have a look at this
    Home Made ECU for EFI Engine -1025926 Home Made ECU for EFI Engine -1025927 Home Made ECU for EFI Engine -1025928 Home Made ECU for EFI Engine -1025929
    www.youtube.com/watch?v=K_fpNcJUpcQ
    This ECU has following features:
    1) Adjustable Idling Speed.
    2) Cold Start feature for better cranking in winters. Just starts in first Attempt.
    3) Fully Controllable Ignition Timing (Advance/Retard) no need for Advancer in case of CNG.
    4) Injector Duty Cycle is Programmable (Rich/Lean).
    5) Cooling FAN can be set at any Temperature.
    6) Fuel Pump runs only if Engine is running.
    7) One can tune it for racing to extract maximum output from the Engine.
    8) It can be set on Economical Mode for Extra Fuel Saving.
    9) Engine Maximum RPM can be limited at any set point. To enhance the Engine Life.
    10) Injectors can be disabled just by giving one Pulse so there’s no need of Emulator for CNG.
    ECU Inputs:
    Intake Air Temperature Sensor, Throttle Position Sensor, Manifold Absolute Pressure Sensor, O2 Sensor, Oil Pressure Sensor, Knocking Sensor, Coolant Temperature Sensor, CAM position Sensor, Crank Angle Sensor, VVT Feedback Sensor.
    ECU Outputs:
    3-Fuel Injectors, 3-Ignition Coils, Idling Air Control Valve, VVT Solenoid, Purge Valve, Radiator cooling FAN, Fuel Pump, + RS232 port for Data Monitoring
    more than that i made all this just for Fun, Engines r my Babies
    Best Regards
    Engr Asad Hameed
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    Congrats. Keep it up
    misteek's Avatar
    Jun 2008
    Rawalpindi
    28
    1,281
    8 Post(s)
    wow thats great..please tell us more in detail which parts you made your self and what capabilities is it capable of? thumbs up
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by misteek View Post
    i made the ECU (Design + Fabrication + Coding)
    Engine: Suzuki K6A VVT DOHC 12Valve
    Best Regards
    Engr Asad
    shariqak1's Avatar
    Nov 2006
    983
    Good work bro..... Keep it up.
    Speed costs money. How fast do you want to go?
    shariqak1's Avatar
    Nov 2006
    983
    Quote Originally Posted by hameeds01 View Post
    Best Regards
    Engr Asad
    How did you write software for it? I mean u must have got the values from original ECU for the valve timing and other controlling of the ECU or you have set all the values by yourself and then fed them into PIC micro controller?
    Bilaltq's Avatar
    Mar 2004
    Select City
    25
    10,311
    10 Post(s)
    Whoa... that's truly amazing! How long did the process take you? ECU's to me are just a mystery, all except the error codes which... I just clear off every time they come on. That's all
    Awesome job!
    This comment was made by a person with a tested IQ of negative 9.
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by shariqak1 View Post
    no i don't have a Factory ECU, i calculated most of the values, i am a Research Engineer & doing Research in Engine Control Unit.
    first i opened the Engine completely & get knowledge about its working then i wrote my own algorithms, i know its not a simple JOB, but Engines r my Love
    shariqak1's Avatar
    Nov 2006
    983
    WOW.... that must be the tremendous effort....!
    I am also interested in these ECU and engine related things but quite beginners level though. Thanks for sharing.
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,102
    5
    184 Post(s)
    11 Thread(s)
    great tallent my friend (Y)(Y)
    www.facebook.com/performancepartslahore
    Site Banned Follow
    TeamAMS1's Avatar
    Dec 2011
    Peshawar
    119
    do you see injector duty cycle and pulse width through the alogrithm method? like most rom editors? and what base timing and total timing was used here?
  12. #12
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by TeamAMS1 View Post
    Injector Width is calculated from a set of Equations that is a function of MAP, CTS, Engine Speed, TPS, Angular Acceleration
  13. #13
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    very nice,, lets hope our indegenous car industry is developed.. we desperately need it..
    top documentaries " Tears of Gaza"
  14. #14
    furri's Avatar
    Mar 2010
    25
    570
    MashaAllah ! you are one talented fella....keep it up !
    As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride! ==========www.Performance-diy.blogspot.com
  15. #15
    hash4u's Avatar
    May 2005
    37
    24,080
    16
    380 Post(s)
    13 Thread(s)
    13
    awesome job
  16. #16
    tauseef's Avatar
    Dec 2003
    Auckland
    255
    2 Post(s)
    Nice work. Question.. wat sensors are u using to sense the engine parameters?? did u actually build them??
    Amazing things happen when you turbocharge a TOYOTA!
  17. #17
    hameeds01's Avatar
    Jul 2005
    892
    19 Post(s)
    Quote Originally Posted by tauseef View Post
    How one can built SENSORS?? dude i just designed the ECU, any ways
    ECU Inputs:
    IAT, TPS, MAP, O2, CTS, CAM Angle Sensor, Crank Angle Sensor, VVT Feedback Sensor, Battery Voltage as Reference, Oil Pressure Sensor. currently i am not using the Knocking Sensors
    ECU Outputs:
    3-Fuel Injectors, 3-Ignition Coils, IAC Valve, VVT Soleniod, Purging Soleniod Valve, Fuel Pump Motor, Radiator Cooling FAN.
  18. #18
    Khan_Saab's Avatar
    Apr 2010
    Peshawar
    24
    331
    11 Post(s)
    Marvelous JOB Thumbs up
    Ustad ji mere ko apna chota rakh loo
  19. #19
    omer1982's Avatar
    Apr 2009
    34
    531
    Exceptional work my friend....(Y)(Y)
    ‘Whosoever chooses to follow guidance, follows it for his own good; whosoever goes astray, goes astray to his own loss.’ (al-Isra’ 17: 15)
  20. #20
    shazaryab's Avatar
    May 2008
    52
    380
    Excellent work.any planes for producing it in quantity for marketing. I have a cultus carby 3 cylinders need a Timing Advance Processor can you make one? if yes let ma know the price.
