Sir, wheelbase isnt that impt in handling. The stiffer suspension links, additional stability bars, tire width, ground clearance, rear coilovers makes the difference. I can give a example of toyota crown on standard suspension, and toyota starlet rwd on circuit tuned suspension. both with same engines for example, 1jz or beams engine., starlet will be more stable
