Cutting size ring
Sent from my SM-G900F
Marks
About to start
One board cut with outter diameter
Now marking placing inner board
Inner board marked
Inner board cut
As I was working my self there fore could not take pictures while cutting
Both cut with differ hole sizes
This ring fit
It's does fit.
There are couple of pictures taken by a friend while I was applying glue to join the two boards. Those will be uploaded once he sends me
I have put it in sun light to so that the clue can be cured.
so you are making it flush mount? nice. make sure you use glue plus screws to hold the two boards together. if you are going to carpet/poshish the board then you should leave extra space around the outer ring to compensate for the covering material otherwise sub will be a very tight fit and will be very difficult to take out of the box
oh boyit requires alot of hard work and patience something I can never manage loltwo thumbs up (Y)
Madhouse 12. I have done it before as well.
Asfand. It's job of two days. I my self am doing is slowly as I don't need it. I am just making it for doing the project
By the way. For the time being I am waiting for a subwoofer which I don't want to buy a new one as I won't be keeping it. Any one selling 12" subwoofer
Any updates?.
Some body give me old 12 inch woofer to proceed [emoji14]
Any update spano bhai
