Its not about the adjustment, my alto has adjustment screws as well. On factory settings, city has a pathetic throw
Wow, thats simply awesome. .you are right, its worth it. .
@sha2eb and @biloo Outcome can be like this aswell
Thank you very much for turning respectable fellow citizens BLIND
Lit street versus dark alley @keiworks12
Didnt get you ?
:). Yes haha
only if the respectable fellow citizens are crawling on the streets
It looks as if the light is so bright to cause glare to oncoming pedestrians and drivers. I dont think projectors should cause that 'HID in halogen reflector' glare...
Enviado desde mi GT-I9500 usando Tapatalk
Rightly pointed out. Projectors are designed in a way to keep the beam below a certain point. Hence the glare is nowhere close to the usual HID kits.
can projectors work in headlights that use a glass cover to spread the light, e.g khyber, instead of the regular clear plastic ones we see today....
Yes they can. ..but the cut off would not be as clean
sorry mate but you clearly dont get the idea of Hid projectors the car in the pics above has proper bi-xenon projectors not hids in a halogen reflector so you get a proper cutoff with no glare
After installing projectors in my vitz
I dont see any glare bro....its the perfect HID projector cutoff. There is not even a little light above cutoff. And i dont think people will have a problem with lights shining on their knees
They look like the projectors found in car accessory shops? Is it? Also the orientation of the cutoff is for the Left hand drive countries. It should be Right hand spec..
Dont know much about that stuffGot these installed and my night driving problem is solved
These definitely seem to be replicas buddy.
Agreed on the point that the throw is much better than stock lights
i recently purchased Accord Cl9 projector lens from Bilal gunj at Rs. 1500 for pair - It was taken off from CL9 genuine headlights. Will share pics once I install HID in it - I have retrofitted them in Datsun 120Y headlights!Btw its a long job and difficulty is about medium level -
Quite some alteration needed to retrofit those into the datsun. Do share the result please
