there is another pipe coming from tappet cover and going to the air filter box, maybe also branching to the engine block, can you get a pic of that too, i suspect that has also been messed with
the pipes need to be reconnected properly
the rubber ring at the carburetor throat also looks like it needs replacement.
if you still have those steel pipes you should re connect them, these green ones probably won't last as long
