Sardiyaon mei engine me se white smoke nikalta tha ab kabhi kabhi black nikalta hai. Engine oil decreasing kya matlab?
Please yar some more people come sab mil ke apna apna mushwara den
Today went to Suzuki Central, GT Road Rwp. They fixed noise from clutch pedal and steering for free. Courteous staff and very helpful always.
As in above post member answered you.Tell me first if you bought it used or its your car from startAs in my cusins mehran 2012 model non euro 2 had same problem actuly he installed ac from outside and that created the problem as you maybe need to install 2 way radiator it may be expensive but it will not heatup the car About rubers you will find in any market but they maybe of low quality so consult 3s dealers as they keep geniune things
Sry bro I live in LAHORE.
Headgasket. I will share pics later of it.
Compound has no effect on resale. Contact the suzuki authorized dealer. I never encountered the rubber No idea about the auto sunshades sry.
Yar i bought used about 3 years ago. 3s dealers kahan hai karachi mein. Un ke paas agar jaon ga to mjhe pata hoga to woh wahan rubbers lagaarn ge na? Aisay hi thori lagaen ge!
Whats a 2 way radiator?
SalamCan anyone explain with regards to ignition coil fault to be mixed with headgasket failure.May be I m facing same issue.Thanks
2 naali radiator
Had faced that and best thing to do is Change coil first if problem is not solved than change gasket
ThanksIs is normal for temp needle to move b/w 40 to 60 as the car moves or gets stuck in traffic. Fan auto without thermostat
this is normalmine used to do the same
Thanks a lot ekdrifterI was feeling as this was some problem and was quoted various solutions. Got the radiator cleaned and cap changed.
just do not open head gasket first solve coiland use coolant
Yar will some one tell me can we get an remote controlled sunshade for mehran for rear winshield
I haven't seen one yet. Ask someone who can make it for u.
Someone kon?
Need some help regarding mehran ac. When i move my hand near the ac air vents they are very cool and chilling but that much cool air is not coming on face nor legs
Where is this oil coming from?
Bhai mehran k ac ka itna hi throw hai k grill k samna ao to hi air feel hoti hai..
