I think someone is mixed up with tappet cover gene and gasket, are you sure you have opened up head not tappet cover its been 3000 hours and I just opened once last month as my camshaft was broke.
Kia wo sleeper or baby shoe b sath aya hai
Nahi bhai jaan is generator k sath sirf ek adad plas aur qalin ka piece free mai ata hai :D:cool:
Haha you guys have no idea how i fit all the things with two very naughty kids
Acha mujhay laga parha likha gene hai sleeper pahen k chalta hai
Yeah U r absolutely right.And i think i am the culprit here.It should be this tappet cover gene that i need to replace
hahahaha waqas bhai wo whatsapp walay naughty bachay
Tell me components of ATS for a 2kv generator. thanks.
ats kit2 contactor 30amp 1 auto manual switch2 timers2 relays1 box
any circuit diagram ?
aoa all suggest me a solution to it tried everything currently its like new cylinder(crankcase)new rod new rings old piston runs perfectly fine take all the load start on half self with ats the issue is blow by from the breather pipe
can you please elaborate about type of blow is it smoky or clean air?
Yes. Hyper kids it was too hot and humid outside so i took it in my bed room in AC to fit all the things. But bacha party nay khoob enjoy kia.
Smokey
Sent from my HTC One X using PW Forums mobile app
1x MAIN changeover Relay = Rs 5001x manual changeover (I hope that's already installed) just for manual over ride incase relay don't work not necessary.if your gene starts on GAS without problem then,
1x two-way double switch for auto , semi auto, manual switching = Rs 252x timer circuit = Rs 1001x flasher circuit = Rs 1502x 8 pin 12v relay = Rs 1202x 220v Relay with base = 260soldering wire = 30solder-able wires = 206 wires male-female grip = 251x plastic box (use can use icecream box/jar too )if your gene starts on petrol than converts to gas,2x timer circuit more needed. = Rs 100.
my ATS used 4x6 blank plastic board to make cover it contains,on-delaygas checkpetrol timerpetrol delayself on & off
yeah bachay bht hyper htay hain lol cute cute sharartain
bro according to me the size of ring and piston might not be according to size of bore in crankcase or you have not positioned the rings properlyas the openings of the two top rings should not be parallel
@gastech Installed gaskit on 3 kva Lutian with ATS . and it's working great. No leakage no need to adjust choke and no need to install solenoid and most important thing my generator start on half self. Great Quality. And i must say paisa Wasool Product.
Can post pictures of ats and what was total cost of installing it
Hi! Guys EID-Ul-Fitr ka Chaand Mubarak and a very Joyous EID to all Pakwheelers and their families.
