Hello, I have a 2012 Daihatsu Mira ES and the eco idle indicator light is flashing. Can anyone tell me what does this mean? Is the eco idle system not working? Thank you
Bump
Sent from my Nexus 4 using PW Forums mobile app
Anyone?
No body has bought this crappy car yet ...maybe @ PakWheels!!
btw are you Ahsan's brother??
please post a picture of dash so instrument panel is visible. just a hunch i may be wrong is there a button on gear shift click it on & off. In a Nissan Tidda sedan (in UAE) there's a button on gear shift which enable / disable eco function
bro it means, ur going to ecology mode, n if u drive it under 40km/h so ull get 30.0 km/L like hybrid cars, may b m rong but i heard about it so thought to share wid u guysrest is in DAIHATSU - News
Dude if your car shuts off at signals means its working
Sent from my A900 using PW Forums mobile app
Issue has been resolved, it was just because of an ecu reset due to changing of batteries.
Mods, close this thread.
Sallam bro, hope you are doing good and enjoying the ride .. !I got my car two days back and having same issue .. ! how to solve it .. ?
thanks for the help .. !
I am having the same issue its blinking and it does not get off on signals .. :sany solution to that .. ?
After driving car for some time it must turn to green and the car will only shut at signal when there is green Eco Idol light, Thanks
I have been driving my car for quite long but it turned green once n not after that ..... after how much driving does the light goes green ??
Sent from my HUAWEI G610-U20 using PW Forums mobile app
After driving it to a specific speed or time it turns green !!The problem is that most mira es in pakistan are accidental and with blown airbags so the system might have got damage when your car had accident !!If you post your cars interior pic I would be able to verify if its not front hit so system is damaged or not ?
And there is a button of eco idol and pls check if its turned off from there!! Hope it will work and its connected via abs sensor so if abs is not working it wont work
Yar i need to ask about Mira ES. I am about to buy one and i tried the car for a little while, first of all tell me when it shows ECO IDLE in orange color in the meter what does that mean ? And when does it go green ? When i push the Eco idle off button the ECO IDLE FROM THE METER GOES AWAY and when i drove on that the car gave me 15km per litre with AC. And when i drove it on ECO IDLE orange color in the meter it gave me 14km per liter ? Can you anyone explain please ?
On orange it means you are driving fast not under eco mode , so if u drive under green , you will get an average of 21-24 km/l and a minimum of 19 with a/c
I have a Mira e:S by the way with Push start and all other options and with airbags too ( for sale )
Well the car i was driving never showed ECO IDLE in green ? :S
Was the eco idol working the display it self changes its colours to indicate how you are driving , Maybe the eco mode was off or anyother problem as I already mentioned that they are all imported accidental and that may have caused the system to malfunction
