the spark plugs will not show any tune data on a 1km lounging run, the only way you can read a plug for mixture data is doing a controlled run under specific load - like motorcycle carburettor tuning.
You now have the correct length and specification plug in your engine. If you are experiencing some lag in initial get up and go then get a replacement ignition coil and retest.
