Bro i dun hav any idea about islamabad .islamabad members can give u a better advice .if the steering is making squeezing sound , may b the steering column bush is very hard wich is making the sound .if the car is lowered from on side , once again chk for the suspension especially the shocks .most probably the shock is damaged .for all the things u hav to find a sincere a capable mechanic , electrician , denter n painter .for that , get help from other senior member of pakwheels especially from islamad bad .other than that if u need any help from my side , you r more than welcome
