Plz tel me where is overdrive button located in every (model 2008)
I dnt think there is any over drive button in every...howevet shift lock button is there.
Simply check on gear shifter
it has no button on it only a button on top of it......i am asking this bcs my car get heat up when i drive at 80 km/h and its like engine is screaming for next gear ..
Check your radiator there must be blockage or thermostat isn't responding and are you using coolant or water
Coolant bhai
How do i know that there is blockage or thermostat isnt working and by the way what is thermostat sign is located
Every is 3 gear automatic just like any other 660 cc...there is no over drive in Every
Not all 660cc have overdrive but some do ie my alto AT has overdrive
4 speed or above have over drive option , 3 speed auto doesn't! You won't find more then 4 speed in a 660cc
jab aap ki vehicle optimum temperature pe ati hai to thermostat valve open hota hai agar woh stuck hojaye to coolant circulate nai ho pata jis say overheating ki problem ati hai kuch steps hai un ko aap follow kerlo1-check your thermostat valve in boiling water2-thermostat switch jo limited temperature pe janay k bad fan ko automatically on kerta hai
i have auto cuore with 3 gears.. it does the same engine screaming thing... but doesnt heat up...
drive at 70ish... thats the max drivable speed of this every...
bhai faan to chalta hai wo b automatic but jab city may 40-50 km ki drive kerta hoon to driver seat k paas wali jaga kafi garam ho jati hai
Pas wali jagah ko maro goli ,engine tou over heat nahi hota
Just let me know one thing pani boil ker rahi hai k nai
good one
does the 5th gear on manual trans.. and 3rd gear on 3speed a/t.. have the same gear ratio?
Salam bhai i have every wagon aur is main overdrive (od) ka option hay . I get average of 12 on 110 speed and nearly 15 at 80 speed
Apke pas konsa model hai bhai...??
