The UAZ-469:
Engine
2,450 cc petrol, in-line 4-cylinder, water cooled, 75 hp (56 kW) at 4000 rpm, 166.7 N·m (123.0 lb·ft) at 2200 rpm
Fuel
76-octane petrol, tank capacity is 78 litres
Transmission
4-speed manual gearbox, 2-speed transfer shift, 4-wheel drive
Front axle
Live axle with leaf springs, drum brakes
Rear axle
Dimensions and weights
Empty weight with fuel: 1,650 kg (3,638 lb)
Max. gross weight: 2,450 kg (5,401 lb)
External dimensions (length/width/height): 4,025 mm (158.5 in) x 1,785 mm (70.3 in) x 2,050 mm (80.7 in)
Wheelbase: 2,380 mm (93.7 in)
Tread front/rear: 1,453 mm (57.2 in)/1,453 mm (57.2 in)
Ground clearance: 220 mm (8.7 in)
Tyre size: 215 SR 15
Wheel size: 6Lx15
