You dont need a seperate Oil Cooler, just get a Toyota 80 series radiator in perfect shape (the auto transmission version) and clean transmission cooling lines with no bends and cloggs. Also make sure that the thick rubbers behind gear lever assembly is properly attached. It provides heat resistance from undercarrige and sound insulation. Also check if the gear shifting is ok on all gears and kickdown.
