Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
Like Tree22Likes
Thread: Which is the best motorcycle engine oil???
    Amss's Avatar
    Mar 2012
    70
    Default Which is the best motorcycle engine oil???
    I want to know which is the best available motorcycle engine oil..
    Specially when it is to be used in zero meter engine..
    asjdsm's Avatar
    Apr 2009
    30
    3,301
    50 Post(s)
    3 Thread(s)
    bro there are many threads and posts regarding 'best engine oil' ,, search them...
    many people prefer havolone for both 70 and 125..and some like zin 4t..
    i have used even attock oil and found no difference .. but in long term usage i prefer havoline..
    goodluck searching
    imranbhatti's Avatar
    Nov 2005
    38
    4,363
    69 Post(s)
    11 Thread(s)
    I have found Shell AX5 as best available Motor Cylcle oil in market specillay for new Bikes.
    Exploring Machines is my Passion...
    Site Banned Follow
    michaelg's Avatar
    Apr 2012
    Miami
    5
    Castrol GTX is one of the best engine oil for motorcycle,you can use in your bike.
    Juste's Avatar
    Aug 2011
    1,970
    23 Post(s)
    I use Caltex Havoline oil for my bikes.
    Your bike is zero meter like mine then you have to change your first oil on first 300kms.
    Reasons
    1. the oil which comes with new bikes doesn't have good quality. Its thin too. When you change the oil examine your old oil and you will notice it wl be too oily and thin.
    2. New engines parts brush/rub each other and sometimes there will be tiny worn out pieces of these parts in engine oil. But this doesn't happen to every new bike.
    3. Change your bike oil on every 1000km.
    31.5497 N, 74.3436 E
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    Brother if u can spend Rs. 650 then go for LiquiMoly racing 4T.It is imported oilo from Germany and does not get black or loose its colour even after 2000km.
    All these stupid havolines,shells and castrols re just recycled oils used by goraas and then packed in Pakistan to make us believe that these are genuine oils of international companies.I have a Gs 150 and havin no issues even after 2000km of usage
    Best of luck bro
    bc003mzy's Avatar
    Aug 2006
    32
    27
    @Haji_John,
    From below link i just found that it is 20w40 Grade oil. So is it suitable for GS150. Although suzuki recommends this grade, but i read on pakwheels from other users to use 20w50 grade oil. So yesterday i did my first oil change in GS150 with Caltex havoline.
    LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Racing 4T 10 W-40
    So kindly advice on this. And also explain how to identify original and fake packing/color of Liqui-moly oil.
    bc003mzy's Avatar
    Aug 2006
    32
    27
    @Haji_John,
    6Forward's Avatar
    Feb 2012
    203
    Engine oil selection for bike
    Viscosity Grade
    If u have new bike then use 10W-40 or 20W-40 viscosity grade only. 20W-50 is viscous oil which is suitable for older engine.
    10W-40 grade will give u more power and fuel economy.
    Oil Quality
    Use API SJ, SL or higher grade, don’t use OBSOLETE grade like API SF, SG or SH
    Especially for bike also use JASO certified engine oil which protects Engine, Gear and Wet Clutch.
  10. 26-04-2012, 04:33 PM
    Site Banned
    Reason
    Spam
  11. #10
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    Brother the link that u have posted is no the one that i use.
    I use racing 4T 20w-50 which can be found on this link.
    LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Racing 4T 20 W-50
    Regarding your question about fake and genuine liquimoly oils.I mailed liquimoly germany to ask about thier authorized dealers in islamabad and they gave me the address and phn number of the one and only shop in islamabad and that is located in I-8 markaz.Dont know bout lahore though
    And about the comment posted by 6Forward pls do some research about relationship between oil grade viscousity and temprature and then post such comments.those people who say that 20w-50 is for older engines are just misleading others.
    Ask any educated person who knows about oil viscousity and he will tell u that the choice of engine oil depends upon temprature and not new or old engine.10w-40 in summers will just simply burn away as it is too thin for 40c or above temps.use 20w-50 in summers and 15w-40 or 10w-40 in winters.
  12. #11
    razaksyed's Avatar
    Jun 2004
    Kabul
    46
    1,003
    You may wish to check the section oil / preventive maintenance and look for a couple of threads on oil - very information; the best being the one by "Storm" and please don't fall in the the trap, some oils may have low viscosity but, are far more superiour. The "thicker the better oil" mainly being a myth of shade-tree mechanics....
    Matchles G3L 1941, Triumph TRW 1951, Matchless G3LS 1952, Triumph T 100S 1968, Matchless G2 1958, BSA B-31 1952.......... I am insane!
  13. #12
    6Forward's Avatar
    Feb 2012
    203
    Which is the best motorcycle engine oil??? -403549
  14. #13
    Amss's Avatar
    Mar 2012
    70
    Currently i m using ZIPEX 4t (20W-40)..
    How is it ??
    Here is the link
    :: MAS GROUP ::
  15. #14
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    Castrol GTX and Caltex Havoline are the two most commonly used oils.
    Not much of a difference in their performance.
    However be sure to get the original oil for your bike.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
  16. #15
    eyeofthetiger's Avatar
    May 2012
    34
    91
    I am also using caltext havoline for my CG 125, but still i am also interested in hearing about a better one. If any one knows a better oil which keeps your engine fit and performs well please share with us.
    Also should there be a different oil in winter and summer or we should use same type of engine oil in all seasons.
    Eye of the Tiger "Be formless, shapeless like water..."
  17. 06-05-2012, 04:51 PM
    Site Banned
    Reason
    Spam
  18. #16
    Haji_John's Avatar
    Dec 2011
    Rawalpindi
    88
    2 Post(s)
    Shell advance 4T but if u can afford liquimoly then go for it as it will last for 2000km without getting black provided that u keep your air filter clean. 10w-40 in summers will just simply burn away as it is too thin for 40c or above temps.use 20w-50 in summers and 15w-40 or 10w-40 in winters.
  19. #17
    May 2012
    34
    91
    What do you think about Atlas Honda engine oil?
  20. #18
    May 2012
    34
    91
    Quote Originally Posted by Haji_John View Post
    Is genuine Liquimoly oil easily available, and what price tag? how often the air filter should be cleaned?
  21. 26-12-2012, 01:48 PM
    PakWheeler
    Reason
    commercial
  22. #19
    ibrarshah1979's Avatar
    Dec 2012
    Sahiwal
    43
    Which is the best motorcycle engine oil??? -1102097
  23. #20
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    6,984
    6
    186 Post(s)
    11 Thread(s)
    Price of 1ltr Liqui?
    Dream is not that which you see while sleeping it is something that does not let you sleep.
