if the disc valve (suction plate) area is gouged, get it repaired correctly, then ensure that the clearance is not more than 0.25mm. You can also shape the suction port so that it exposes all at once - you need to widen the V sometimes, and the engine side should be aimed and shaped upwards to enable higher mixture intake.
But I dont think this engine is suited for your purpose.
