Aaqil no mechanic has recommended this trick will consult them lets see what they say
Ohh you also facing same issue bro this issue has been the most frustrating
issue so far for me at i have gotten replaced seal three times two times as trick
a mechanic said i can replace seal without opening clutch cover after reclament
it worked for few thousand km but again it leaked again went to mechanic he replaced
seal it worked only for few hundred km' again started to leak oil 3rd time as recommended
honda mechanic went to him he opened clutch cover replaced seal but it worked for few km's
only
This is common issue with cg125 engine Oil Seepage From Tachometer Cable
Mueen first of all make sure oil dipstick is tight means after tight with hand
just give one final push using plier if it still leaks than you gotta replace seal
i was unable to find its seal but finally at one shop who deals in motorcycle
accessories and generator he had one o ring seal which fitted on dipstick
and now when oil dipstick is tight i don't see any leakage
Before this i had went to honda mechanic who replaced two times seal but i was
facing oil seepage issue went to buy seal but it was no where available not at
honda parts dealer he had cg dream dipstick but i was shocked when i saw it
had no seal so it was waste of money buying new dipstick as oil seepage is only
because of seal or o ring on dipstick
