A.O.A!!
I own a 2004 Santro Club... The problem I am experience is that when I switch on the head lights, for about 30 secs the panel light, the hazard button light, the defogger light and the tail lamp gets lit up... But after that all these are off and will not light up again even if I switch off and again switch on the steering light switch... Head lights and brake lights working fine... And now from few days, one of the head light is not switching on at normal position, works fine at high beam...
I took the car to an electrician, firstly he replaced the problematic headlight beam but even it was not working so it became evident that it has developed some other fault... He checked all the fuses which were ok... So he concluded that actually the light switch is faulty and that repairing would cost around 1500/- whereas new is around 4000 - 5000/-
Please give /share your opinion over this matter... If there is problem in switch then why it only works ok for approx 30 sec always and that too for the first time when I switch it on... After that no response until I operate it the next day...
