Subject : Tips for Santro Hope they help!
As I have been using santro since 2005, and have some tips to share to santro users for their santro to perform best .
Always take care of your snatro's air filter its what your santro breathes. clean every week and change every two monts. it conuts for your santros best cng average.
If you have stock gereral tyres installed. go change them at earliest as those general tyres gonna ruin your suspension and they all amounts to all handling, performance and other issues.
when ever you feel that your santro is not performing well like it consumes petrol or it revs higher during idle speeds or uneven engine rev. first chage the spark plugs. if your spark plugs are new then open the bonnet disconnect your battery wire (only one ) wait 5 mins reconnet the battery wire.
now your ECU is reset to its factory default values and in most cases it will solve the problem.
Always try to avoid weaker batteries in santro. the battrery volts do count for performance of your snatro.
Again I repeat to keep your air filter clean.
In the end. I love my Santro and I have won highway reces on Karachi motor way( with cultus, xli, gli, 2.0D, city, cuore, alto) and only lost to 1.8 vvti with just my stock santro. Tip is to know where the torque is and which revs gives you more.
If you feel that the reply posted in your topic is irrelevant or the topic posted is in incorrect section, kindly click the Report Abuse button for that specific reply or topic[Mod Edit]
