Hi,
I need to pass the car through MOT. Only SRS lamp is on - The seats were not in the car, but the seatbelt lamp turns off when the seatbelt is buckled. It has dual airbags, no glove box. Where should I start looking?
Our mechanic has worked with MB for like 30 years, he told me not to change the Atf oil, the car gears smoothly ( 722.4 ) and he told me if I change it, I could ruin the valves inside the valveplate because of the new oil cleaning everything. It has 470,000 km on the clock exactly.
For the rest of the maintenance- Changing every fluid and filters. Any tips on servicing the cooling system? Temp is at a perfect 83 degrees ( roughly ).
I am impressed. Only a few faults which I need to fix - Tighten front wheel bearings, do an alignment, change 4 tires, left indicatorlamp for the front and weld the exhaust
Ps- Where can I buy cheap MB parts online? I have all the part numbers.
