no i wanted to know if you could manually adjust the rpm with it rather like manually set idle to 900rpm instead of 800rom for example, i can do this on my Mercedes using Mercedes STAR diagnostic and its really neat.
i was wondering if toyota two way scanner also have this ability, what i found out it does not allow you to manually set any rpm you want but it allows you to reset it to factory specs.
