Up for sale is the Flex 3401 Forced Dual Action Polisher.
Flex is a company which perhaps needs no introduction and neither does their DA polisher but for people who dont know here it goes.
Flex is a powertool company based in Germany. Produces the highest quality products that are there and yes they charge for it as well.
The Flex 3401 DA polisher is a true DA polisher. They describe this product as a Dual action polisher on steriods and it is nothing less than that !!
The pad moves in a forced duration even when you apply pressure to it and almost never stops rotation like other DA from Meguiars or Porter cable. Combine that with the large stroke length, the FLEX can remove existing holograms from black finishes and has maximum correction ability.
This is perhaps the only polisher that can come VERY CLOSE TO A ROTARY CORRECTION ABILITY !!
Thanks to the direct orbital drive, very little heat develops on the surface, which is ideally suited to temperature-sensitive finishes (i.e., ?soft? clear coats). The FLEX XC3401 VRG Orbital Polisher makes it almost impossible to burn the paint !
The FLEX Orbital Polisher has a seven-fold microprocessor offers constant speed control by tachometer generator, soft start, accelerator trigger switch, restart protection after power interruption, overload protection, temperature monitoring, and speed selection. This makes the polisher insanely difficult to malfunction or get burnt out. It lasts years and years without any problems !!
This is THE best DA polisher you will find out there.
This polisher was imported from the US and is therefore a 110v and you will need a standard 110 to 220V converter to use it. A lot of people out there are using it including me and causes no problems what so ever.
I have added a 25ft cord to the existiing 9 ft cord of the polisher so that one can take it all around the car without any problems even if you are doing a truck !!
The polisher includes its backing plate and I will throw in a few pads for a very small price which I have only used once so they are spanking new !
This baby is insanely expensive. The base price of it is USD 330. Add shipping ($60) and duty on it too if you plan on purchasing it and please refrain from low balling.
PM me for offers or contact me on my cellphone 0333-2357448
Pics will be added in the night,
Happy detailing.
Usman :)
