Aoa Guys. i m new on pakwheels, i recently got a new ride nissan note 2007. it has a got nissans HR15 engine. i heard a lot about this engine regarding fuel economy. but what i m getting is max 12kpl. i want to get it tuned for a better mileage. plz advice me from where i should get it tuned. REGARDS.
Brother any good mechanic will service the throttle body for Rs. 1,000/-.
12km/l is not bad for a 1.5L with auto.
Max you can get is 14km/l.
Clean the fuel injectors, spark coils, check spark plugs, clean/replace air filter and use a 50;50 HOBC mix.
@hasnain139 with throttle body cleaning there will not be much of a difference the fuel economy you wish get please disconnect / do not use aircon, drive with light foot and 13.5 is tops you can get in urban driving & 15 over the highway (long stretches)
Throttle body would not help because it has little to do with fuel economy. Make sure your air filter is not clogged. It is the only thing that is in direct relation with economy otherwise its ECU who is incharge of adjusting Air to Fuel Ratio. It tries to keep it to certain level
thanks brad its servicing was done all fuel filters and everything was changed 1000kmz earlier. i used 75;25 HOBC mix i ll try a 50;50 as well tks
thanks atta i will take it to G8 nissan centre so that professionals could do it ... as in isb now ,,,
thanks i would be happy with 13.5 in urban capsat bcz i m not getting that on hwy,,, on my last trip from lhr to isb it avgd to 12kpl almost, not literally. i would go by ur advise n see the results ... and i always keep a light foot :"( though ,,,
thanks affan ,, tomoro i ll go get it checked underhood... cheers for advise ,... any good mechanic in isb u guys would advise plz,,
any good mechanic u people can refer ,.,.,.
if it aint broke, don't fix it. Kindly do not mess around with the throttle body
so wat should i do Akbar to get max out of it ,,, kplz i mean ..
wese sardi ma i never use aircon ,,, figs r w/o aircon
second third..dont mess with throttle body..its not part of service..
ok siRRR...
Thanks atta i ll do so n first instance ?
I think driving style is the most important thing.
