@rezbaluch
Thanks reza bhai. These body kits are custom made and I paid 16k including body kit paint job i.e., 16k for body kit + its paint. Still its around plus 16k +/- 2k.
If the guy is also offering programing ecu / atleast electronics (like safc etc) for controlling the fuel then you must go for it. But keep in mind the budget case as I think shipping alone would be around 5k.
For turbo you must have the electronics parts compulsorily as it produces more boost but u can use a small supercharger (producing around 5psi) without electronics and just going with bigger injectors. Supercharger producing around 5psi is quite good for around 150hp and a lot of torque giving hard time to b16's and 20valve's I think so.
Also stock internals with proper fueling are capable of handling boost well around 15psi. U must have seen thread on daewootech.com
But if you install supercharger then you would have to say good bye to AC as the compressor pulley and its place will be used by supercharger.
But I have a cheap solution for you and is luckily in Karachi. Mailed you about that kindly check.
Regards.
