How slight are we talking about? An mm over or more?
An oversize bore (more than an mm) without modifications to the head and valves is calling for trouble. The squish clearance (Piston to head) won't be even and will result in decreased performance, also the valves won't feed the required amount of fuel the piston will need, and nor will it displace heat like matching valves will do.
