Congratulations. On your purchase. May it serve you well
1)ev driving in ima machines is a tricky thing. The best you can Do is. Go upto speeds between 35 and 50. And then relax the force on the pedal., pressing it very slightly, the car might decelerate a little but will convert to ev in a 3 to 4 seconds.
2) All Japanese cruise systems have this. It's because in Japan the maximum highway speed is 110. So the companies restrict the cruise till 110 only. So the maximum speed for cruise is 110.
3)you can identify the version by looking at its chassis number. It should be on either of the front door (A black sticker probably), or under the hood. Should start with GP
Mechanic i can't comment. But u can tell you this, it's a pretty simple car to maintain. Good knowledgeable person is all that is needed, no hifi mechanics are required. Because the fit is a mild hybrid and hence works mostly like any other petrol car. .
Do post your fuel economy stats.
And drive safe (y)
