Hi All well I had been seeing many of the respected member's talking about faulty Cat converter or Chocked CAT converter and many of them break it clear because they don't know what is the solution for this fault. I has seen many vehicle's getting their CAT cleaned at RT's Diagnosis but I was Curious that what those guy's are doing are they also breaking the Cat's and clearing them out by the traditional method's or they are doing some real work there. So I finally managed to had some time to meet RT's owner and requested them to clarify what they are doing. So upon my request they showed me the vehicle cat which they were servicing and also they gave me the photo graph's to see the difference so I am sharing those here for the ease of other people's who think that there CAT's need servicing or they are blocked..
Where is this RT's diagnostics, what do they charge for a chocked CAT?
I dont know about the pricing info brother will try to get the rate's from them. Btw they are in Rawalpindi.
Aoa, Can u please mention their location in Rawalpindi??
they are on chaklala road.
bro can you tell there location in detail.
Sent from my GT-I9300 using PW Forums mobile app
They are on Murree road upon reaching from Islamabad side when you cross the 2nd fly over of chandani chowk on your left there is Benazir Bhutto shaheed hospital and there is the first road turning to the left which is known as chaklala road they are on that road
@rajaatta .... how much do they charge for cleaning of cat? What process they use to clean it??
they do it by Cat cleaning machine's.
Dear raja, you have collected all the information but you don't know how much they charge for the cleaning.Also, u have been campaining for RT's diagnosis on a Pak wheels a lot. Are you getting commission on referring pak wheel members / visitors to visit RT's diagnosis for all their problems?
I have been visiting the RT's Diagnosis since april this year after been looted from many mechanic's which cost me more than 30 thousand. then I visited them on the suggestion of one of my office colleague and my problem was solved in just 1500 rs what a huge difference.
MashAllah, you are capable of developing a cng-hybrid system (ec 1 or something) and you can't fix your own car, wow
Could u please elaborate that what other mechanics had suggested you, which u have done on catalytic converter blockage issue for which u paid altogether 30,000 rupees to different mechanics?
The guy has given the contact number ov the workshop But people are still seeking details of address, location, Process and charges From him. M Surprised.
Sent from my HUAWEI G610-U20 using PW Forums mobile app
I have the vitz 2007 1000cc the problem was check engine light and some time ABS light light up and the car start's shaking and hesitate's too much some time if I depress the accelerator pedal fully it wont respond . mechanic's had done the tuning many time's they also remove the CAT from my car. Engine wiring harness changed with new one ,ECU replaced, Throttle body replaced but the problem was still there. The fault was only one wire coming from my accelerator pedal was damaged and got shorted with body which was making a lot of trouble got that fixed from RT's Diagnosis in 1500/- with the full IT unit scan and basic calibration's and the fault is gone and now my ride is running smoothly just a loud sound of my exaust finding one used to get it fixed back.
you are right sir.
WHAT ????? are you kidding ..
Dear Raja, if your intension of introducing RT's diagnostics workshop was solely for others here at the forum to benefit then I respect ur intensions; but again since you are in touch with them (RT diagnostics) why not discuss with them all the possible measures one can take to avoid or prolong blockage of catalytic converter and post this on the forum.
yes bro I had my appointment from them on monday will discuss this matter as well will share my conversation with you guy's..
I took my honda civic 1998 for AFR test. The result on the pictures attached. But the guys at RT diagnosis were anable to solve my issue. They could not find the AFR adjuster in my car. So my car AFR is still 20 instead of 14.7.
