Hello Pak wheel members i own 07 Model liana Rxi bought in 08 when it was only 13000Km driven the seller installed italian renzo kit before selling it to us car was in very mint condition till now. Car is driven very very mild on Cng and since 2012 cng has been disconnected properlyi removed cng bec when i use to accelerate high use much A/C the drive on long routes then car do not get start after switching it on i remove the cng for this purpose. but prob not solve car starts only by a single jerk or touch like even it push like not even to give full rotation to tire. now its 2015 and prob is still I showed it to many mechanics but no one can help me and car does same prob casually Engine is 101 per ok no smoking and very good performance current mileage is 67000 and on petrol is 12-14 km/l without A/C. never wiring prob i have tuned to from Suzuki Township motors but no betterment change its plug air intake and resent and remove error fromobd. but no advantage. now tell me any conclusion except selling it
Please Elaborate the problem. Cant understand what u wrote
car cranks and deosn't start (meaning self hi nahi lete)???? or car cranks and doesn't start (meaning self leti hai per start nahi hoti)??
nai car sulf hi nai laiti
car sulf nai laiti
iss trah lagta hai jaisay battey bilkul dead hai
Phir start kaise hoti hai?
the problem is somehow related to battery of the car faced the same when battery died car use to refuse cracking when engine get hot
Check self starter cables.
Sent using Curiosity's onboard communications sytem.
Now using battery of 60 amp still cant sort out i dont why just it a single push just a crack push to take sulf + showed the sulf but it was ok too
i think so i should check its timing belt too may be it stucks
there is always a solution , seems like you need full battery recharge or replacement.....
Is the car getting over heated by any chance?
Does this happen every time you put the ignition on or on certain instances?
Start with the simplest and cheapest solutions. Check starter cables and relays.
I was about to refer this case to Proverbial_slang. He is the master of liana
Car has never been heatup and just like i told u i showed every thing no prob found and this thing occurs casually when car run for more then 20-25 km and i check its battery via ammeter and voltmeter it do not ground current
i changed its battery terminal also and relay box ka aik fused i changed it. but sometimes battery terminal gets heatup alot of positive side only
wasiay aapas ki baat hai similiar thing is happening with my brothers liana .... HANJI liana experts please advise
aapas ki baat on open forum
https://www.pakwheels.com/forums/electrical-wiring-battery-lights/141082-little-friendly-advice
he really is master of liana (Y)
