Pak suzuki / owners manual says to replace engine oil at 5000km intervals.
Do you guys recommend? Need your helf as I am in fix.Regards
Sent from my GT-I8262 using PW Forums mobile app
It depends on the oil you are using.Some oils have a very long change Interval, while some have a short one.If you're using Pak Suzuki's oil then change your car's oil at 5000KM.If you're using oils of companies like Liqui Moly or Mobil1 then you can Increase the Interval from 5000KM to 8000KM +-
Thanks for quick response. Do anybody know which oil Pak suzuki 3s are using as their genuine oil. Further technician of Pak suzuki advocate to change oil at max 4000km. Anybody facing similar contradictions. Regards
I think PS is using repacked Shell or Total's oil!
Thanks
Update. PS use engine oil manufacturered by Total and the transmission oil made by shell.
