As salam o alaikum,
My car is not starting and its cranking all the time. I have found my car trouble codes by linking 2 pins inside OBD connector.
I got 31, 43 and 88 engine light flashing codes, I was able to find the first two codes but I have problem getting the last one "88".
31 ? Pressure sensor ? open or shorted MAP sensor circuit
43 ? Intake air temperature sensor signal ? open or shorted
Please let me know if anyone knows about the last code "88"?
Is MAP sensor do the both pressure and IAT? or IAT sensor is different?
I have checked the voltage for MAP sensor and its showing correct 5 Volts, did also checked resistance on the MAP sensor by heating and the values are changing for pin 1 and 3, but value on pin 2 and 3 remains same.
Looking for help if anyone can provide in this regard.
Thanks.
Abdul Majid
