I am about to purchase a OBD2 dongle for my mehran to diagnose its engine behavior myself...I am curious to know whether mehran is OBD 2 or OBD 1 supported ??? It's port have 16 holes.... thanksUmair
Sent from my SM-G530H using PW Forums mobile app
its jobd and none of el cheapo scanners would work....only suzuki scan tool would work which is used for baleno cultus.
Thanks.. Suzuki 3s has std scanner.. but those idiots never let you see results on scanner... just attaching it and after some clicks said all is well ..
these morons know nothing about fuel trims.....parameters of sensors etc......what they do is.....they only check for errors and reset the data......which u can do simply by removing terminal of battery and charge 1000 rps for it.
That's why help me to get some device like this
till now there z nothing except u arrange for this tool from outside the country.......moreover the ecu of mehran is very primitive to tell u all live data.
Too expensive for me...
hmmm......offtopic question how's ur mehran going nowadays??
It a better just because weather is good in Islamabad and I did not drive our if city... .. still purge valve I bypassed and no check engine light.. this never gone blink in Suzuki
Damn too much typo mistake
Frankly speaking my old carby car which was 2012 model was way better than this new car... this is a headeche
you can easily drive out of city after bypassing purge valve dnt wry and dnt take tension......every car has some problems......carby mehran was better because it was in market for 23 years and every1 understood it better.i have driven efi mehran its way smooth and better ac and fuel economy than carby one.
Yes ac and drive is good.. have you also by pass purge valve???
yes i had by passed purge valve sometime ago on my relative's car then i was once changing bulb of left rear light and i observed pipe....i changed it with better and long pipe.....but after that no issue in city driving of lahore but haven't experienced on long route.
That's fuel tank breather pipe... only sound of air being sucked into throttle is annoying after bypassing purge valve. Otherwise all is good
I did this
fuel tank breather pipe is behind rear left light.......but u have done is also good....just tape the openings of valve and pipe to prevent dust from entering it. this is how ur EVAP system works.....the air sound u hear is from downside of canister vent.....purge open when car picks up race and on idle it remain close....u can check b14 terminal of ecu also which is signal wire of ecu for this purge valve.
Yes.. also thinking can I change this purge vakve with carby idle up valve.... does it make sense?
u can check that valve by connecting it with battery.....most often its good and fails seldom.....but u can change it with any 12v vsv solenoid which old toyotas even mehran carby had for ac idle.
Thanks... is this easily available..??
