Yes vickey bro u r right it will never give more than 35+
Data was taken from an indian web site :embarass:
Check this, got is from Suzuki UK
[h=4]DIMENSIONS AND WEIGHTS[/h]
[TABLE]
<tbody style="margin: 0px; padding: 0px; border: 0px; outline: 0px; vertical-align: baseline; background-color: transparent; ">[TR="bgcolor: transparent"]
[TD="bgcolor: transparent"]Overall length:[/TD]
[TD="bgcolor: transparent"]2145mm (84.4in)[/TD]
[/TR]
[TD="bgcolor: transparent"]Overall width:[/TD]
[TD="bgcolor: transparent"]760mm (29.9in)[/TD]
[/TR]
[TD="bgcolor: transparent"]Overall height:[/TD]
[TD="bgcolor: transparent"]1075mm (42.3in)[/TD]
[/TR]
[TD="bgcolor: transparent"]Wheelbase:[/TD]
[TD="bgcolor: transparent"]1430mm (56.3in)[/TD]
[/TR]
[TD="bgcolor: transparent"]Seat height:[/TD]
[TD="bgcolor: transparent"]780mm (30.7in)[/TD]
[/TR]
[TD="bgcolor: transparent"]Kerb Mass:[/TD]
[TD="bgcolor: transparent"]183kg (403.4lbs)[/TD]
[/TR]
[TD="bgcolor: transparent"]Fuel capacity:[/TD]
[TD="bgcolor: transparent"]13.3litres (2.9 UK gallons)[/TD]
[/TR]
</tbody>[/TABLE]
[h=4]ENGINE SPECIFICATIONS[/h]
[TABLE]
[TD="bgcolor: transparent"]Engine capacity:[/TD]
[TD="bgcolor: transparent"]248cc[/TD]
[/TR]
[TD="bgcolor: transparent"]Engine:[/TD]
[TD="bgcolor: transparent"]Four stroke, liquid-cooled, SOHC[/TD]
[/TR]
[TD="bgcolor: transparent"]Bore:[/TD]
[TD="bgcolor: transparent"]53.5x55.2[/TD]
[/TR]
[TD="bgcolor: transparent"]Compression ratio:[/TD]
[TD="bgcolor: transparent"]11.5:1[/TD]
[/TR]
[TD="bgcolor: transparent"]Lubrication:[/TD]
[TD="bgcolor: transparent"]wet Sump[/TD]
[/TR]
[TD="bgcolor: transparent"]Fuel system:[/TD]
[TD="bgcolor: transparent"]fuel injection[/TD]
[/TR]
[TD="bgcolor: transparent"]Transmission:[/TD]
[TD="bgcolor: transparent"]6-speed constant mesh[/TD]
[/TR]
[TD="bgcolor: transparent"]Drive:[/TD]
[TD="bgcolor: transparent"]chain[/TD]
[/TR]
[TD="bgcolor: transparent"]MPG:[/TD]
[TD="bgcolor: transparent"]85.87*[/TD]
[/TR]
</tbody>[/TABLE]
[h=4]CHASSIS SPECIFICATION[/h]
[TABLE]
[TD="bgcolor: transparent"]Front suspension:[/TD]
[TD="bgcolor: transparent"]Telescopic, coil spring, oil damped[/TD]
[/TR]
[TD="bgcolor: transparent"]Rear suspension:[/TD]
[TD="bgcolor: transparent"]Swingarm type, coil spring, oil damped[/TD]
[/TR]
[TD="bgcolor: transparent"]Front brakes:[/TD]
[TD="bgcolor: transparent"]Disc[/TD]
[/TR]
[TD="bgcolor: transparent"]Rear brakes:[/TD]
[TD="bgcolor: transparent"]disc[/TD]
[/TR]
[TD="bgcolor: transparent"]Front tyres:[/TD]
[TD="bgcolor: transparent"]110/80-17 M/C 57H, tubeless[/TD]
[/TR]
[TD="bgcolor: transparent"]Rear tyres:[/TD]
[TD="bgcolor: transparent"]140/70-17 M/C 66H, tubeless[/TD]
[/TR]
</tbody>[/TABLE]
