Aoa.....what's the price of atlto vxr timing belt and timing bearing?
Sent from my HTC Desire HD A9191 using PW Forums mobile app
Well. Dont know the exact price but both items are not expensive. Btw why u are changing belt anf bearing?
Sent from my Sony Xperia TX using PW forums mobile app
Get genuine ones will cost around 3k for both things but will last longwr theb locally made
Sent from my A10 using PW Forums mobile app
Car done 80000 kms that's way.....
You can take her upto 60,000 miles
Sent from my iPhone using PW Forums mobile app
which coolant for alto??
If any one want to wash the radiator .. please open radiator by some good mechanic..usually radiator guys open radiator by jugaars and they never install it with proper 4 bushes..things which removes for opening the radiator :1) left side front wheel.2) front Bumper3) balance Rod.
Zic coolant 3 bottles no water
Wow never knew that thanks for sharing
Timing belt should be replaced after 100000 kms.
We replacemed on santro at 85k and it was weak and consideration of quality of ps then one shold change it early
One. More thing as f10a needs more visits for tuneup Always use some hi octane like 20liters of normal petrol and 10 lit of hi octane keeps engine clean and alto will require less visits for tuning
Estimated cost
1k
ok thanks will be updating
brake pads go wild in summersi removed wheel covers from front wheels as they need air one disadvantage of not having alloys
Hey EK bro, I was planning to buy Alto but after reading your thread I am afraid it will not be a wise decision. What else can I get in 400-500K budget? I need Better fuel consumption, resale, cheap parts etc...
A very informative post, thanks mate for sharing it with us.But can you please answer a few of my concerns? I own a Alto VXR 2006 model and after spending a lot of time at workshops I finally am able to drive it like a normal car (no hickups etc)
Why so harsh on stance? I believe the ride height is already too much that even if you get it dropped a few inches the car would never touch the ground.
Why do we need to remove the ventuli (steel/card board cover on air intake) on petrol?
Can I get any 1000cc EFI installed in this model?
My car won't go more then 100kmph (without AC on CNG) and 110 or 115 on petrol, any ideas how to make it go more fast? or faster then a FX? Though the pick is good but it just looses everything when shift to 4th
No matter how much I try and spend I just can't get rid of the noises from here and there, my mechanic told me that every Alto has this problem, is that true?
No need to drop the height. Everybody knows the kind of speed breakers we have here in Pakistan.That blockage is put to make carby non ecu cars work on CNG. That definitely affects the petrol mileage to some extent.Yeah you can. But where would you find a quality engine? That's the matter of concern.Looks like your engine has gone weak or carburetor is not functioning properly.And lastly, Say hello to Mr. Suzuki for all the noises.
get a cuore. good economy because of smaller engine and reliable. resale is ok. parts are not cheap but last longer.
