Main ne noise wala masla to pehlay hi solve kar liya tha, factory say hi bike ke parts aisay lagwaye thay ke noise bilkul bhi na ho, top class engine nikalwaya or phir uski fitting karwayi, bike ka handle, alignment, wiring, paint work, visor fitting, ( it took 7 visors change to stop it's noise and vibration ) driven the bike in factory (by staff obviously ) to 25 km with different tests, and then changed it's oil in the factory at 25km driven. coming to the point sprockets laganay say Vibration bohat ziada kami aajati hai sirf front sprocket change say hi half vibration khatam ho jati hai, main ne ye sab test alag alag kar ke daikhay hain, pehle sirf front sprocket change ki, baki sab kcuh genuine rakha, phir rear change ki, phir CDI unit change kiya step by step aik aik item change kar ke dekhi phir end per in sab ko combine kiya or ab full result mere samnay hai, ek last or full change karna hai but us say bike ki looks marr jayen gi, Chrome muffler lagana hai issay plates nikal kar, full open exhaust millay ga bike ko to 5km tak top speed or increase hogi iski, i'll try it in a day or two
[I]Deluxe ko 5th gear sirf engine ko rest daine ke liye diya gaya hai, 5th gear ka performance say koi taaluk nahi hai ye bus engine ko sakoon daita hai, lekin main ne 5th gear mein bhi jaan daal di hai ab, meri bike ka 1st gear 40, 2nd 65, 3rd 80, 4th 100 or 5th 118 tak jata hai, bike gear hi nahi maangti, bike ka saaans lamba ho gaya hai jaisay, main 5-6 din say daily 100 km chala chala kar check kar raha hoon isko, ke iski top speed mein kami to nahi aayi chal chal kar, ya kisi kism ki koi noise, ya fault to nahi aaraha modification say, lekin aisa kuch nahi hai, bike bilkul perfect chal rahi hai kisi kisam ka koi masla nahi hai
Meri to apni bikes hain main ne CG Dream ki sprockets nikal kar is mein daal di hain, just CDI unit mujhe aik mechanic say purchase karrna parra hai Lahore say Rs.800 ka, ager aap market say sprocket lo gey to Crown Lifan ki 800 mein mil jayegi, aur ager CG ki genuine dalo gey to almost double kharcha aayega, ab last modification main ne Chrome muffler ( plates nikal kar ) ki karni hai, definitely chrome muffler black deluxe pe bohat bura or cheap lagay ga lekin main ne result nikalna hai lazmi aik bar, ager kamyaab hua to main brand new Deluxe Black Muffler ki plates nikalwa doon ga or phir wahi laga kar chalaoun ga[/I]
Yes bro, meri apni bikes hain mujhe kya tension, main ne to chala kar baich hi laini hoti hain 4-5 hazaar loss kar ke, lekin shok ka koi moal nahi, baharhaal mera experience yahi hai ke jis bike ne set nikalna hai wo start pe hi set niklay gi, jis bike ne gandi nikalna hai uski chahay running karlo, time pe oil badal lo, wo ghatya performance hi day gi
Sirf Bigger CDI Unit laga kar dekho 2005 model wala ya is say pehlay wala, is say kafi farrk parray ga, ager is say bhi ziada chahiye to phir front sprocket 15 teeth ki daal do rear genunine hi rehnay do, pura meter maaray ga
no difference at all, bike has same sharp pick up and long long very long gear bearing, bike gear hi nahi mangti kehthi hai bus chalayi jao, sprockets ke sath bohat farrk parta hai bike ka saans lamba ho gaya hai, bike ka RPM 8 tak bhi chala jaye lekin bike gear nahi mangti no matter if it's in initial 3 gears
Buri baat, aesi baatein nahi kartay
