[TABLE="class: mbike_datas, width: 440"]
<tbody>[TR="class: odd, bgcolor: #F7F7F7"]
[TD="class: mbike_property"]Engine type:[/TD]
[TD="class: mbike_detail"]10 cylinders, 4-stroke, V10[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Displacement:[/TD]
[TD="class: mbike_detail"]8277cc (505.72 cubic inches)[/TD]
[/TR]
[TD="class: mbike_property"]Bore ? stroke:[/TD]
[TD="class: mbike_detail"]102.4 mm x 100.6 mm (square) [/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Cooling system:[/TD]
[TD="class: mbike_detail"]Water cooled[/TD]
[/TR]
[TD="class: mbike_property"]Power:[/TD]
[TD="class: mbike_detail"]499.93 HP (367.7 KW) @ 5600 RPM[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Torque:[/TD]
[TD="class: mbike_detail"]712Nm (72.6 KG-m) @ 4200 RPM[/TD]
[/TR]
[TD="class: mbike_property"]Throttle:[/TD]
[TD="class: mbike_detail"]Cable operated[/TD]
[/TR]
[TR]
[TD="class: mbike_property_title"]Valves[/TD]
[TD="class: mbike_detail_indent"][/TD]
[/TR]
[TR]
[TD="class: mbike_property_indent"]Valve train:[/TD]
[TD="class: mbike_detail_indent"]OHV, variable[/TD]
[/TR]
[TR]
[TD="class: mbike_property_indent_end"]Valves per cylinder:[/TD]
[TD="class: mbike_detail_indent_end"]2[/TD]
[/TR]
[TD="class: mbike_property_title"]Fuel and ignition[/TD]
[/TR]
[TD="class: mbike_property_indent"]Sparks per cylinder:[/TD]
[TD="class: mbike_detail_indent"]1[/TD]
[/TR]
[TD="class: mbike_property_indent"]Fuel supply system:[/TD]
[TD="class: mbike_detail_indent"]Fuel injection[/TD]
[/TR]
[TD="class: mbike_property_indent_end"]Ignition type:[/TD]
[TD="class: mbike_detail_indent_end"]Digital CDI[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Engine mounting:[/TD]
[TD="class: mbike_detail"]Transverse[/TD]
[/TR]
[TD="class: mbike_property"]Lubrication system:[/TD]
[TD="class: mbike_detail"]Wet sump[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Gear box:[/TD]
[TD="class: mbike_detail"]Automatic 2-speed[/TD]
[/TR]
[TD="class: mbike_property"]Clutch:[/TD]
[TD="class: mbike_detail"]Wet, slipper, cable operated[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Final drive:[/TD]
[TD="class: mbike_detail"]Chain[/TD]
[/TR]
[TD="class: mbike_property"]Motor oil:[/TD]
[TD="class: mbike_detail"]Synthetic[/TD]
[/TR]
[TR]
[TD="class: mbike_property"]Starter:[/TD]
[TD="class: mbike_detail"]Electric[/TD]
[/TR]
[TR]
[TD="class: mbike_table_separator, colspan: 2"][/TD]
[/TR]
[TR]
[TD="class: mbike_title, colspan: 2"]Chassis and suspension[/TD]
[/TR]
[TD="class: mbike_property"]Frame type:[/TD]
[TD="class: mbike_detail"]steel, Backbone frame[/TD]
[/TR]
[TR]
[TD="class: mbike_property_title"]Front[/TD]
[/TR]
[TR]
[TD="class: mbike_property_indent"]Suspension:[/TD]
[TD="class: mbike_detail_indent"]Cartridge - upside-down[/TD]
[/TR]
[TR]
[TD="class: mbike_property_indent_end"]Brake:[/TD]
[TD="class: mbike_detail_indent_end"]Single Disk[/TD]
[/TR]
[TD="class: mbike_property_title"]Rear[/TD]
[/TR]
[TD="class: mbike_detail_indent"]mono shock, Mono arm[/TD]
[/TR]
[TD="class: mbike_detail_indent_end"]Disk[/TD]
[/TR]
[TR]
[TD="class: mbike_title, colspan: 2"]Other[/TD]
[/TR]
[TD="class: mbike_property"]ABS available:[/TD]
[TD="class: mbike_detail"]No[/TD]
[/TR]
</tbody>[/TABLE]
[video=dailymotion;xlrwy7]http://www.dailymotion.com/video/xlrwy7_8000cc-millyard-viper-v10-hits-207mph_auto[/video]
It's not a custom bike.
