it was cleaned with diesel and then with kerosine oil using brushes are clothes.
i being the project manager thought of leading from the front
after all this the bay was cleaned with surf and then water and was dried with a cloth and was let to dry as the moisture was still there
now comes the engine cleaning that was to be put in the car
all the parts were opened and were cleaned.
gud goin!
this is the engine BLOCK after seperating it from engine HEAD
Here is the B16A Inlet Manifold
And this is the TypeR Inlet Manifold
Ok thanks buddy!!
Oh btw.. Did you check the play in pistons? I hope they are perfect!!!
i not only checked the play but i also did the compression testing and found all four above 200 psi here is the compression testing kit
Nice Project :),,, Spano one out of topic question, Where can we get compression tested in ISB?
nice work
Loving it (y)waiting for the outcome
Good Going...!!B/w..I Don't Get A Reason Of Opening Head.....!! Is It For Putting New Gasket Or Just For A Sake Of Cleaning...!!@Vaqas1....Compression Testing Can Be Done Anywhere...Just Need To Open Plugs And Put A Tester And Done Accordingly.....!!Maxtorque Must Have That
@vaqas1, you can contact me if you want to do it.
@SER_GTR, Head was opened completely for cleaning.old genuine gasket was used. later you will see in the pictures
here is another view of the engine Block
and this is a view of the transmission
now comes the engine HEAD being cleanedit was opened and all parts were dismantled and were cleaned lubricated
Gudluck bro
here is the HEAD fitting
this is the rod that takes oil for Vtec operation and rockers arms are fit on it its cleaned and lubricated and put in its position another view rocker arms are being fitted
mashaAllah u got nice neat piece
bohot bohot mubarik ehtesham! do let me know how the car is running
