if you ground the pulse generator it will put a heavy load on ignition system when you try to start the engine , and second think , any one can judge that from the sound of engine , atleast i can
well i tell you one more thing , if you ground the pulse generator than the ignition system can be destroyed , .........you ever noticed that your car sound system , ac fan motor , cigret lighter , and some other things goes off when the starter motor is running ,,,,,,,,,,,,,,,,,,,,these all switches off , and same as the iginition system , ,,,,,,,,,,,,,,,,,,,,so if the ignition system goes off while the starter motor runs then how the car start ? ,,,,,,,,,,,in this situation car wont be start , but in real it really starts , so how it goes ,,,,,,,,,,,,,,,,,,ignition system get current first from a ignition switch and when starter motor runs this curuit cuts off , and at that time it gets current from starter motor through a diode which also called electrifier by electrican , but infect it is a diode , ,,,,,,,,,,,,,,,,,,,,when you ground the pulse generator this diode can damage , once it happens with me , this diode is located inside the startor motor soleniod (commonly called Kuppi by electrician) , and car starts on a very very very long self when this diode gets out of order ,
and the car security system also ground the pulse generator ,
