@tonton16
Any turbo can fit in a Daewoo's engine. Due to additional air for combustion, more fuel is required. You need bigger injectors, high flow fuel pump, high pressure MAP and different engine management (ECM). Also you have to lower the CR (if running more than 1/2 bar).
If you can arrange the ECM, wiring, MAP sensor and other stuff from the lanos turbo, you can make your daewoo run on turbo. (y) It will be better to swap complete engine from Lanos as it is bolt on.
@kashmir1
The most easiest and low cost solution has been already mentioned by @saadshaukat (y)....
The costly solution is to replace the rear window with the one having defogger. You can get the rear defogger window of Daewoo for around Rs.6000/= and Wiring + Switch + Labor costs around Rs.1500/-
@saadshaukat
(y)
@hammed
Around 12-13Km/L in local and around 15Km/L on long route (average speed of 100Km/H off-course on highway ).
