Does anybody know where the cabin AC filter is located in this vehicle? I took the glove box off but couldn’t find it
There is no Filter in it but there is a "Mesh" like a Material , similar to our in house Split A/C. It's Washable.
Yes, exactly. I have seen that mesh/jaali in person but I don't know where it is fitted in the car or how to take it out.
Will try to share the video with you as soon as possible as i have done it in my colleagues car.
Thanks, please do so at your earliest. Will be very helpful.
Cleaning Cabin AC Filter of Hijet
We also have this problem lekin 1 mechanic Jo sirf in japenese dabbo ka Kam karta hai us ne kha agr 9 litres de rhi hai to ap khush qismat ho q ke me ne aj Tak is se ziada nhi suna ke kisi ne di hai 9 litres se ziada
Salaams, Bhai do you still have this vehicle?
JazakAllah for the tutorial. I was able to take out the jaali and clean it. It was badly choked which affected the airflow of the vehicle too. I washed and installed it back after drying. Now the flow of AC is much better Alhamdulillah.
Thanks , Do It at least after 6 Months to get maximum Air flow & if you have high dusty environment then I would recommend to do it after every 3 months.
As you have done it once , next time it would be much easier to take this Filter out.
Same meri bhe yahi problem ha kea haal kia ap na abhi ha ap k pass yeah nahi....or fan bhe direct ha mera mechnic na kaha ha ecu card lu naya or fan automatic karwao
Aoa, I found softcopy of HIJET in japanese, any one can google TOYOTA PIXIS VAN OWNERS MANUAL.HIJET and PIXIS van are identical.regardsAtif
do u ppl have Manual Of Hijet in Soft Copy??
Mera bhi yahi same question hay Kya koi janta hay please....
Hi FriendsCan anyone recommend to me the best engine oil for Daihatsu Hijet Cargo 2013 model 4X4 Full cruise, driven + 1.5 Lac KM. As Toyota Highway Motors Karachi recommended me Toyota Proton Plus SAE 10W30 and right now using the same. My vehicle daily running is 200 to 250 KM. and changing oil at every 3000 KM
I shall be very thankful to you .
Aneel Kumar
I have KIXX ATF D III automatic transmission fluid. How many km’s do I change this? My car jerks every gear change.
hi sir, i have Daihatsu Hijet Cargo 2014 model Manual gear with 4WD option. during running when i slow the speed and need to change lower gear, my car's engine stop/shut down. please advise as soon as possible. (i have check engine oil level, coolant and air filter are ok)
Same question
Same question kese pata chaly ga
I wanted to buy hijet but after reading the thread, I became worried
