5w-30 should be good for Hi-Jet.But many people feed it 20w-50 because its like loader car (like suzuki Bolan).however first choice 5w-30 and 2nd should be 10w-30 or 10w-40 as max.
It has manual transmissions or Automatic?
Thanks for suggestion Transmission is automatic.Which compony oil is best
Thanks for suggestion.Transmission is automatic and which oil company is best.
The very simple choice is ZIC ATF. Price is Rs. 530/L.Or you can check with Toyota's workshop and I am sure they will recommend T-IVYou can choose whatever you feel better. ZIC ATF comes in 1L packing in red color plastic bottles. Toyota's T-IV comes in 1L packing but in Tins.
Thanks u very much.Engine oil kis company ka behtar rahega.
ZIC, Toyota, Shell, Caltex, Total, LM, Mobil, all are good.But better to stay away from Micking, Kixx, Proforma, Qalco, FUCUHS, and many similar less famous companies.
thanks ur rply.apne 5w30 kaha zic ki online site pe ZIC XQ 5W40 hai.in dono mai kia difference haii m new is liye kuch pata nahi oil k bare mai
ZIC don't have 5w-30 viscosity.You can try Shell HX7 price is Rs. 2640/4L bottle.Or Total quartz 9000 price is Rs. 2700/4L.LM also has 5w-30 but its very expensive.
5w-30 and 5w-40 are two different viscosity grades.Every company recommends particular viscosities for their engines. And first choice should be to follow recommendation.
However following sites are for your study.
http://www.tribology-abc.com/abc/viscosity.htmThe Car Maintenance Bibles
How Much engine oil use in hijrt cargo 2009
Hijet m oil kitna refill hota h.aur transmission oil kese check karte hn hijet m Kindly mujhy batayen m n abhi purchase ki h 38000 km chali hui h aur 4.5 grade hn please update
I guess it take 3 or 3.1L engine oil. Find its manual to know exact viscosity & quantity.there will be a dip stick for gear oil. If it has, then pull out, wipe it well, and read. The oil type should be mention on it.if it doesn't have dip stick, then consult the manual first before letting it handover to oil change shop or mechanic..
Asalamoalaikum actually mn ne apni car mn engine oil 20w50 zic ka synthetic oil dala hai 2 litters to ab wo start nae ho rhi car module dehatsu hijet
Wa Alaikum Salam.
Car not starting just merely after changing the engine oil does not make any sense to me. Problem seems to be lying somewhere else.
First check for battery. See that if its absolutely fine and perfectly charged, or not? If YES, then move to checking ignition (a.k.a "Sulf"), starter motors, etc.
And 2L engine oil seems to be fairly less. I do not have exact idea about the quantity of engine oil reqd. in your car, however, I think it'll be somewhere around ~2.5L.
Please do not drive the car, when engine oil is under-filled, and / or its level is very low. Extremely low oil level, low oil pressure, etc. can be disastrous for the engine.
Hi FriendsCan anyone recommend to me the best engine oil for Daihatsu Hijet Cargo 2013 model 4X4 Full cruise, driven + 1.5 Lac KM.As Toyota Highway Motors Karachi recommended me Toyota Proton Plus SAE 10W30 and right now using the same. My vehicle daily running is 200 to 250 KM. and changing oil at every 3000 KM
I shall be very thankful to you .
Aneel Kumar
Sae 10w-30 is best
Both 10w30 and 5w30 grades are acceptable and are also recommended in the owner's manual. Both have similar viscosity (cst) @ 100C. However, 10w30 oils are usually found as mineral based so I prefer 5w30. Plus, better cold start flow too.
I've been using total quartz 5w30 in a 120K driven Hijet since initial import at 60K kms with a 4500 - 5000 km change interval with regular maintenance as needed and so far no issues.
Thanks, boss for your valuable information. Furthermore, I need to change also gear oil for Hijet auto transmission vehicle user manual recommend for ATF D3 SP, which is not available in Pakistan. Which oil you are using for gear oil and how it is performing? please share your thoughts, please
i recently bought a Hijet 2011/16which is 1,51,000 K.M. driven.last owner used shell HELIX HX3 20W-50 .i want to use zic 10w-40 (whic is thinner and synthetic) or any other suitable suggestion will be wll be come.thank u so much
I would suggest 5w-30, API SN, Fully Synthetic engine oil from any reputed brand, if your car's engine health is perfect.
