3rd gen1krf 1000cc Same engine I think..
Which device are u using ? I have ancel v 1.5 bluetooth adapter, currently using with my 1st gen vitz but didnt tried it on 2nd or 3rd gen yet.
Which android app brother?
You guys need to check this post for detailed discussion on this topic:
I have vitz 2006 (obd2 elm 327) will it work?
4000 i have it and I'm selling it
Ancel a202 obd 2 scanner is not working on my vitz 2007 model 2009 import its obd 2 scanner what should i do need help???
Dear Spiderman
i have read all your comments to help out the people who having issue with connecting ELM to ECU. I having the same I have belta 2007 1.3 ELM scanner is unable to connect with ECU, please help me out.
is it still working fine for you? are you able to read ATF / AT temperature? (trans oil)
I am no longer using that device.
Use car scanner for portable device by using Bluetooth. Other apps have lack of communication protocols. I'm using on vitz with ELM 1.5 obd2 Bluetooth scanner.
Hi,
I have Toyota Vitz 2009 and trying to connect Torque using OBD2 connector that I purchased but it's getting stuck at "Checking Model" (check attached image). I followed the steps that are provided here. But it's still not connecting. Can anyone please help me what I'm doing wrong?
Download paid one. Go in the profile settings. Show advance settings.In configuration strings option try Toyota strings. Will work.
