nope i tried nthng like tht nd jb bike thanda hota hai tou sahe hota hai normally i dont knw if ths issue is due to overheating...bt overheating kyun horhe hai jb bike randomly max 7rpm tak jata hai othrwise tou 6rpm per he har gear par chla rha hun
i thought its better nt to do anythng by myself....wesay i am experiencing ths prblm randomly jb b bike rush wagera men phansay ya zada chlay tb esa hota hai otherwise thek rehta hai....
It's not a difficult task just remove the clutch rubber and you'll see teri screws, tighten or loose them... I presume apka clutch bht zyada loose hoga maybe
Sent from my X9076 using Tapatalk
boss loose hoga ya tight?i think tight zada hoga may be nd which screws nd rubber one with handle or the 1 near engine?
Try both ways bro... End handle k pas walay screws
okay bro thnkx (y)
bike wheel should not turn na when clutch is pressed nd bike is in gear bt on double stand?my bike wheel is rotating with clutch pressed i checked....wht to do nw?u teied adjusting from clutch handle screw bt tyre is still rotating wht to do?
Ok got it... Your clutch is extremely loose..... Lever bhi apka loose rehta ha na?
lever konsa wala bro?
i tried to loose it nd tight from clutch handle screw bt tyre dint stopped completely but its speed increased nd decreased with rotation of tht screw with handle jbk abhe tou bike bilkul thande hai
Adjust the screw in such a way that aapke clutch half chornay k baad tyre rotate karay.... It's the safest and ideal position for CLUTCH PLATES
bro i tried all the ways from clutch handle screw to the other 1 near engine bt no faida tyre phir b ghoomta hai jb clutch daba kar gear men dalo nd i am checking it by putting bike on double stand.... there is smthng else wrong
Last thing to do go to mechanic... Even Honda mechanic will do it for you... Don't you worry it's not a big issue
okay i will nd i think its must to visit a mechanic nw....the thing is i am just afraid k wo kuch ulta sedha na karden....thats why abhe tak mechanic k pass nae lekar gya btw thankx alot bro
Congratulations Bro ... May Allah bless you riding it safely & keeping it tidy
Jazak Allah
Yar yBr k rear shoks adjustable hain like GD. ? Or not ??
Wail hai, Be namazion k liye ..
Yes the YBR has 5 adjustable points for rear shocks. By default ye 3rd point pe hota
Bro , one more thing , plz tell me is its clutch is soft or hard like CG ??N also gear shifting is smooth or u have to press with attention to shift/change any gear ?
Bhai jaan clutch is soft nd gear shifting is also very smooth agar ap clutch ke setting proper karo tou....pehly i had ths prblm of clutch soo bad k bike overheat horha tha band hojata tha full clutch press kark b agay chal rha tha tou i adjusted clutch myself now its 100% okay nd gear shifting is very very smooth pehly neutral men bike ko lanay men 5 min se upar time lagta tha nw its perfect
